ATP100W wpa ssid not working
yes it is allowed and cable (RJ45) computer works well.
I assume this is the other SSID; and confirm that it works with this client?
Yes EFFERV_INVITE is OPEN and is outgoing on DMZ whit an ip of 10.10.10.0/255.255.255.0
And EFFERV_PRO is WPA2_Personnal wifi outgoing on LAN1 with an ip of 192.168.10.0/255.255.255.00 -
I presume you have already done this obvious test; anyway what if you change wpa 2 in open? (to create the same conditions of the other ssid)0
you are right I have try.Anyway this PRO wifi works only if I set the outgoing interface to other than LAN1.But my requirement is the LAN1 no other one.I really don’t understand why on this device only it is not working.I have installed 6 others atp100w and wifi works as expected.Thanks for your time0
as far i can see your configuration is quite basic.
Obviously we missing something. In my opinion it could be better backup the configuration, full reset and start from scratch.
Hi this is a long time post but the problem remains.
For now Wifi is working on LAN2 and with rules LAN1 and LAN2 can communicate.
But It is very strange.
I cannot do a full reset for now because I am far of the ATP.
Any other idea ?Thanks
Hi @CcHuMi
Could you help summarize the current problem?
Update:
You may send me a private message when you back to us for help.
Zyxel Melen0
- 221 Nebula Ideas
- 613 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
