2FA Google Auth time sync issue
Fred_77
Fred_77 Posts: 147 image  Ally Member
5 Answers First Comment Friend Collector Fifth Anniversary
Hi all...
this is a question (not a issue yet)..
Google auth as 2fa for VPN  works well, but:
what if the mobile with Google app is in a different time zone than USG/ATP?
Android App has a function "Time Correction" (not sure it's the correct name), but as far as i know IOS version doesn't.
Has anyone tried this scenario yet?
Thanks in advance
Fred
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    Time zones do not affect Google Authenticator’s mechanism, as it uses the Unix coordinated universal time (UTC) timestamp internally.
  • Morgan69
    Morgan69 Posts: 7 image  Freshman Member
    edited June 2022
    All you have to do is make sure your Google Authenticator app's time is synced correctly. Launch the app, tap the Menu button (three dots), and go to Settings > Time Correction for Codes > Sync now. You should find that your Authenticator codes work properly after this.
    mypascoconnect
