IPsec VPN with NAT
We are soon to start using a software system that is hosted by the softwre supplier. To allow our staff to connect to it they require us to set up a site-to-site VPN. I've never done this before but have read the tutorials and I think I'm OK with the process of setting up the VPN Gateway and Connection.
However, they have also asked that we NAT our subnet behind a single /32 IP address that they have provided. I'm happy with the principle of that but I'm not sure how to actually set it up on my firewall.
Could someone give me an idiots guide on how to proceed please? I'm using a ZyWall 310.
Thanks in advance.
Thanks in advance.
Hi @SMarkG
this article might help...
https://support.zyxel.eu/hc/en-us/articles/360001378633-How-to-setup-SNAT-in-a-VPN-tunnel
Fred0 -
I think this is the setup you want
[ZyWALL/USG] How to configure VPN SNAT on Zyxel gateways – Zyxel Support Campus USA
Thanks very much @Fred_77 and @PeterUK. I'm sure I read those article previously (I've read so many trying to figure this out that I've lost track!). However, if I've understood it correctly, the 'NATted subnet' and the local subnet have to be the same size (so there's a 1:1 translation between the 'real' IP addresses and the addresses presented to the remote peer). The help section for the VPN Connection says,
Outbound Traffic
Source: Select the address object that represents the original source address (or select Create Object to configure a new one). This is the address object for the computer or network outside the local network. The size of the original source address range (Source) must be equal to the size of the translated source address range (SNAT).
Destination: Select the address object that represents the original destination address (or select Create Object to configure a new one). This is the address object for the remote network.
SNAT: Select the address object that represents the translated source address (or select Create Object to configure a new one). This is the address object for the local network. The size of the original source address range (Source) must be equal to the size of the translated source address range (SNAT).
But we've been asked the following "We prefer you to NAT your subnets behind a single /32 IP. An IP is reserved by us on our system on a per customer basis whenever this is possible. NATting your subnets means we do not need to know your physical subnet ranges and you can change your subnets without effecting the Tunnel and your VPN connectivity."
I'm struggling to understand how we do that whole subnet > single /32 IP thing, or if that's even possible. Isn't that Port Address Translation (PAT) rather than NAT? Or am I completely misinderstanding what's required here (as I said, I've never done this before!)?0 -
Well I did this which is what you do your end:
All the other end sees is 8.8.8.8 as the source.
Oh, I see! Must admit I didn't even think this was possible when I read "The size of the original source address range (Source) must be equal to the size of the translated source address range (SNAT)" in the help.
So (to confirm I've got my head around this!) the Source is my local subnet (the one I want to 'hide'), the Destination is the subnet at the remote end (in this case the software supplier) and SNAT will be the single IP address they've provided to me and want me to NAT everything to???0 -
in Policy for local policy you set single IP address they provide
SMarkG said:Oh, I see! Must admit I didn't even think this was possible when I read "The size of the original source address range (Source) must be equal to the size of the translated source address range (SNAT)" in the help.0
Thank you everyone for your help. It's making more sense to me now so I'll give it a try!0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
