Zyxel Usg 60w wireless local ap not showing up in gui and working bad
sk8erbender
Hi guys ! Lastest update 32 says always offline local ap here is screenshot
What to do now?
Hi @sk8erbender
Can you recall what had be done before this symptom happens? Because we didn’t get such issue like yours before and we’d like to understand further about what will make this issue happen.
5
After the reboot cpu shows 90% and other AP shows as offline but it's not
2018-08-22 12:19:02alertCAPWAPAP Disconnect. MAC:,Name:AP-,Reason:Idle in DISC State,Model:NWA5121-N192.168.0.236:33617
Pinging works
64 bytes from 192.168.0.236: icmp_seq=136 ttl=64 time=0.281 ms
64 bytes from 192.168.0.236: icmp_seq=137 ttl=64 time=0.310 ms
64 bytes from 192.168.0.236: icmp_seq=138 ttl=64 time=0.390 ms
64 bytes from 192.168.0.236: icmp_seq=139 ttl=64 time=0.293 ms
64 bytes from 192.168.0.236: icmp_seq=140 ttl=64 time=0.327 ms
64 bytes from 192.168.0.236: icmp_seq=141 ttl=64 time=0.390 ms
64 bytes from 192.168.0.236: icmp_seq=142 ttl=64 time=0.493 ms
64 bytes from 192.168.0.236: icmp_seq=143 ttl=64 time=0.311 ms
64 bytes from 192.168.0.236: icmp_seq=144 ttl=64 time=0.320 ms
64 bytes from 192.168.0.236: icmp_seq=145 ttl=64 time=0.449 ms
is there some kind of upcoming testing firmware to fix this ?)))
Hi @sk8erbender
5 -
Credit for solving problem goes to Stanley. The problem was with license and more than 2 management AP. Made 1 standalone, everything is working now.Zyxel_Stanley said:Hi @sk8erbender
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
