Voice VLAN setup conflic with existing voice VLAN.
Mastas8
Mastas8 Posts: 1 image  Freshman Member
edited August 2022 in Switch
Hey everyone,
I have a few Zyxel switches.  One GS2210, and two GS1920's.  I am going to use the Voice VLAN Setup for the new phones about to be deployed on site.  If I set this up and tie this to the existing voice VLAN, VLAN100, will this cause issues for the current phones on that VLAN.  VLAN 100 is currently statically configured.  The phones currently on VLAN 100 are being tagged on the phone itself not using the voice vlan oui setup.
Let me know if this is confusing or you need any other information/explaining.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Mastas8
    Welcome to Zyxel community!
    Deploy new IP phones won't cease cause conflict to current phones.
    May I know do you face any problem?
    Please feel free to ask.
    If you need more information for Voice VLAN, you may reference below link:
    Switch VoIP
    Zyxel Melen
  • Zyxel_Melen
    edited June 2022
    Hi @Dustin184,
    May I know what fundamentally vague issue did you faced?
    Is it also Voice VLAN problem?
    Or you may create a new post to share your problem and our agent are willing to help.
    Zyxel Melen
  • Zyxel_Melen
    edited June 2022
    Hi @Mastas8,
    Since I didn't see your reply for few days, may I know is there anything I can help?
    In addition, I want to let you know you just need to make sure your new IP phone have setup right VLAN setting(VLAN 100 tagged out) and connect to a VLAN 100 port, then your new IP phone will work.
    Zyxel Melen
