Interface issues USG60
First this happens a few times every now (1-20 minutes) and then, after a few days I get these every few seconds. Reboot always helps for a couple days until throughput declines again.
I have changed all by cables and done the basics to figure out if this is external issue, but now I went on to try my secondary internet port for a day and I get no syslog errors on it at all.
According to graphs by observium the only notable difference is that eth_base acts differently while using wan1 and wan2 links, red shows my one day test on wan2 link
my config is fairly simple with only one minor differences; dhcp metric and ipv6 - ipv6 is globally disabled so I'd assume that has no impact as should not the dhcp metric.
Any pro tips?
Thanks!
Hi @N77
This log should coming from when physical layer is negotiating when linkup.
May we know more detail information on your environment:
(1) What is the speed supported on your device? 1000M or 100M? (maybe you can let us know the product name)
(2) Please use CLI command shows physical negotiation result when connecting WAN1 and WAN2 on USG
Router# show port status<b></b>
(3) How about the test result if connecting a switch between your modem and USG60?
e.g. Internet------modem-----switch------USG600 -
1)
I am not entirely sure what you mean by product name, other than USG60?Router# show versionZyxel Communications Corp.image number model firmware version build date boot status===============================================================================1 USG60 V4.32(AAKY.0) 2018-07-12 10:31:26 Running2 USG60 V4.30(AAKY.0) 2017-11-23 21:17:51 Standby
Link speed supported is 1000M but I have only 100M ethernet uplink.
2)Router# show port statusPort Status TxPkts RxPkts Colli. TxB/s RxB/s Up Time===============================================================================1 Down 10969779 12495178 0 0 0 00:00:002 100M/Full 6188714 7546128 0 970 10984 03:50:113 Down 0 0 0 0 0 00:00:004 Down 0 0 0 0 0 00:00:005 Down 0 0 0 0 0 00:00:006 1000M/Full 20369606 17957030 0 12468 2222 36:20:56
(I have switched to port 2 now as it seems to be more stable)
3)
I have ethernet link towards my ISP (shared fiber between apartments) and I am blindly connecting to their switch at 100F through ethernet jack in my apartment; ISP -> Shared switch -> USG60
However I have tried adding TP-link switch in between and the behavior is exactly the same.
ISP -> shared switch -> TP-link TL-SG2008 -> USG600 -
Hi @N77
Can you try to fix the port as full 100Mbps on your USG60.
Please use this command:
Router# configure terminal
Router(config)# port status Port1
Router(config-port-status)# no negotiation
Router(config-port-status)# speed 100
Router(config-port-status)# duplex
Moreover, can you also check the port speed/duplex/auto negotiation modes on the TP-link switch settings? And also check the Ethernet cable is 8 pin.
Done but still get the message within minutes after completed12018-08-23 15:21:05debugDefaultkernel: eth0: 100 Mbps Full duplex, port 17
Also since I have TP link in between I can use 1000M link TP-link<-> USG60 and 100M ISP <-> TP so I tried both autoneg on TP-link and USG60 at 1000M and 100 full duplex without autoneg at both per your suggestion.
I am thinking at this point that the eth0 might actually just have hardware failure since everything works ok on eth1. (I see nothing physically wrong with eth0, no bent connectors or such)
I have cat6 and cat5 cables I tried with and the cable is 2 meters so I am gaining confidence in the fact that this is just a hardware failure at USG60 side.
What makes it odd is that reboot seems to help temporarily and it takes couple days before the performance goes really bad and the frequency of messages increases so I was thinking this could be some sort of counter overrun/leak issue too, but then again that should also impact second port?
Hi @N77
I will send you private message for check this issue more detail.0
- 601 USG FLEX H Series
- 480 News and Release
