USG310 Slow speed site to site vpn ipsec
we have just acquired 2 Zywall usg310 to replace our USG60 in order to increase the speed of the vpn between the 2 sites.
The problem is that we do not exceed 36Mb/s while our old USG60 exceeds 90Mb/s we have two symmetrical 600Mb/s FTTH Link, do you have any idea?
Config :
BWM disabled
Firewall disabled
Phase 1 (Vpn gateway)
IkeV1
Negotiation mode : Main
Encrypt : AES128
Auth : SHA1
PFS : DH2
Nat traversal : actived
DPD : Actived
Phase 2 (VPN connection)
Nailed-up: actived
Replay detection: actived
Netbois broadcad: actived
Auto MSS
Active protocol : ESP
Encapsulation : Tunnel
Encrypt : AES128
Authen : SHA1
PFS : DH2
I tested in smb, sftp and iperf I have the same result
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-10.00 sec 42.4 MBytes 35.7 Mbits/sec sender
[ 4] 0.00-10.00 sec 42.3 MBytes 35.6 Mbits/sec receiver
USG60: RFC 2544 VPN througtput 180mbpsUSG310: RFC 2544 VPN througtput 650mbpsYou said that with USG60 90mbs were reached. CPU 100% of the device?About MTU, is correctly setup on both end of the connection? you can reach close to the performance limit of your FTTH connection?Last but not least: are you aware of some eventual BWM from your ISP?
mMontana said:You said that with USG60 90mbs were reached. CPU 100% of the device?- On the USG60 when we are at 90 mbs the Cpu is between 62% and 75%
About MTU, is correctly setup on both end of the connection? you can reach close to the performance limit of your FTTH connection?-I currently kept the default values (MTU 1500 and the MSS in automatic)
- not to my knowledge, looking a bit I can't find anything, I opened a ticket with this one0 -
Hello @Tylerd,Welcome to Zyxel Community!May I know the firmware version of your USG310? and provide the configuration to us for further checking? (you may contact me through private message)Thank you.James0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
