Domain Zone Forwarder USG Flex 100
Niro96
Niro96 Posts: 56  Ally Member
Hello, I am a German Telekom customer and have set 8.8.8.8 and 8.8.4.4 as DNS servers under LAN1. There are also Telekom DNS servers under Domain Zone Forwarder. Can you delete them? Andd have the influence on my existing connection under LAN1?
greeting
Marcus
    PeterUK Posts: 3,887  Guru Member
    You can't delete default Domain Zone Forwarder which I too would like to do.
    However as you have set DNS on LAN1 all of LAN1 will use them its only if your set DNS in LAN1 to ZyWALL that the default Domain Zone Forwarder are used.
  • Niro96
    Thank you.  :)
