IPSec tunnel VLAN to VLAN
Each USG60 VLAN subnet must not be the same and might you try site to site?
The VLAN's are different (192.168.81.0 and 192.168.82.0) I tried Site to site, but does only work for regular interfaces, not if you want to transfer only VLAN.
Site to site works with VLANs
site A with 192.168.81.0/24
local policy 192.168.81.0/24
remote policy 192.168.82.0/24
routing rule
incoming interface
member the VLAN
destination 192.168.82.0/24
next hop
type VPN Tunnel
VPN tunnel the zone for the tunnel
site B with 192.168.82.0/24
local policy 192.168.82.0/24
remote policy 192.168.81.0/24
routing rule
incoming interface
member the VLAN
destination 192.168.81.0/24
next hop
type VPN Tunnel
firewall rules:
from WAN to Zywall protocol 50, UDP 500, 1701 and 4500
One side will need port forwarding for protocol 50, UDP 500, 1701 and 4500 the other side nailed up.
@nielsscheldeman what's firmware version are working on your device?
You may capture packets on VTI interface to monitor the traffic status.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
