SBG5500 VPN connected and running but now showing in vpn -status as active
I set up a new router yesterday and everything runs fine.
I am just wondering, why the vpn tunnels ( 3 ) are all active (ping runs fine,
data flows), but the status randomly shows only 1 or 2 ones as active. firmware is up to date.
Any hints ?
Any hints ?
It seems everything runs well, but sometimes the show is incorrect, right? I didn’t find same situation as your side, do you try to “refresh” if when it happens?
In my settings, I always configure one IPSec VPN phase 2 rule to match one phase1 rule. Is it same as yours? Or you are use multi IPSec VPN phase 2 rules to match one phase1 rule?
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
