USG 110 and VPN Client zyxel
Pier90
Pier90 Posts: 7 image  Freshman Member
edited April 2021 in Security
Hello
I have a problem with VPN Client Zyxel and some computer with win 10 (after update ; with tablet surface): VPN client doesn t word (impossible to connect the tunnel)
Thanks for your help
  • Pier90
    doesn t work (no word lol)
  • Zyxel_Stanley
    Hi @Pier90
    What's the software installed on your PC? IPSec VPN Client or SecuExtender?
    Which VPN Client version is installed on your PC?
    Does the issue still exist after re-installing the software?
  • Pier90
    Hi Stanley!
    * Ipsec vpn client
    * I try version 3.7.204.61.13 & 3.6.204.61.4 & 3.5.204.61.06
    * After re-installing : same problem
    thanks
  • Pier90
    and
    * I have the same problem with 3 PC in win 10
  • artit
    artit Posts: 10 image  Freshman Member
    I have the same problem with 15 PC in win 10 (Secuextender - SSLVPN)
  • Pier90
    PS:
    I try to stop on Win10 the following Services:
    IKE- and AuthIP Ipsec Keymodule, IP-Helpservice, IP-sec Rule Agent
    --> same problem
  • Pier90
    Hi Artit
    Do you use an other vpn client yet ?
  • Pier90
    PS : I disable secureboot-->same problem
  • Zyxel_Stanley
    Hi @Pier90
    I will send you private message for check this issue more detail.
    Hi Artit
    This thread is discussing IPSec VPN client but not SecuExtender.
    Could you open a new thread for your question please :)
