GS1900 V2.70(AAHH.1) firmware
Hi @darcey,Thanks for the information. For non POE variants of GS1900, do you recommend continued use of 2.70?Yes, please be assured to use 2.70 version for non-PoE GS1900.
Jonas,Jonas,0
Same question here....I have a GS1900-48hp running 2.70(aaho.1).It would be nice to know why was v2.70 firmware pulled?1
Hi @darcey, @p4_greg,v2.70P1 is temporarily removed due to a potential PoE stability issue. The switch will stop providing power to the Powered devices and it can only be recovered by re-enabling all of the PoE ports to regain services.PS: This patch is still available by request for the customer who has concerns about the reported vulnerability issue in this link.Regards,
JonasJonas,0 -
@Zyxel_Jonas Thanks for the information. For non POE variants of GS1900, do you recommend continued use of 2.70?
I noticed the absence of POE on Port 1 of my GS1900-24EP so I switched the powered device to another port. I had considered putting in a service request. I will hold off on a firmware downgrade (it appears there are additional fixes in v2.70) and wait for a new version with a fix to the POE issue.0
Jonas,Jonas,0 -
Thank you for confirming. I will stick with it. No issues so far.Zyxel_Jonas said:Yes, please be assured to use 2.70 version for non-PoE GS1900.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
