GS1900 V2.70(AAHH.1) firmware
Hi @darcey,Thanks for the information. For non POE variants of GS1900, do you recommend continued use of 2.70?Yes, please be assured to use 2.70 version for non-PoE GS1900.
Jonas,Jonas,0
Same question here....I have a GS1900-48hp running 2.70(aaho.1).It would be nice to know why was v2.70 firmware pulled?1
Hi @darcey, @p4_greg,v2.70P1 is temporarily removed due to a potential PoE stability issue. The switch will stop providing power to the Powered devices and it can only be recovered by re-enabling all of the PoE ports to regain services.PS: This patch is still available by request for the customer who has concerns about the reported vulnerability issue in this link.Regards,
JonasJonas,0 -
@Zyxel_Jonas Thanks for the information. For non POE variants of GS1900, do you recommend continued use of 2.70?
I noticed the absence of POE on Port 1 of my GS1900-24EP so I switched the powered device to another port. I had considered putting in a service request. I will hold off on a firmware downgrade (it appears there are additional fixes in v2.70) and wait for a new version with a fix to the POE issue.0
Thank you for confirming. I will stick with it. No issues so far.Zyxel_Jonas said:Yes, please be assured to use 2.70 version for non-PoE GS1900.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
