communication with PUBLIC IP
Zyxel1900
Zyxel1900 Posts: 6 image  Freshman Member
edited July 2022 in Security
Hola:
Como puedo tener ping con una ip publica, tengo una zyxel usg1900.
Espero su apoyo.
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    Write the specific security policy.
  • Zyxel1900
    What parameters did you set?
  • Zyxel_Emily
    To ping the public IP of USG1900 from WAN, you need to add a security policy rule to allow service "PING". You can also set "Source" to limit which source IP addresses is able to ping the public IP of USG1900 from WAN.
  • Zyxel1900
    hello
    It is not with the public IP assigned to zyxel, I have ping on that.
    I am referring to the pages that have a public IP that we can enter.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    @Zyxel1900 How about sharing the topology with ip address of devices? It will be helpful to understand your question in the scenario.
