USG20 want to upgrade firmware to latest
I have a USG 20 in use that I need to upgrade, if possible. Is this still supported or is it out of the question to upgrade to a current firmware? Let me know what other info is needed.
Model : ZyWALL USG 20
Current firmware : 3.30(BDQ.9)
The USG20 is EOL and you have the newest firmware0
Hi @ryanchow,The latest firmware for USG20 is 330BDQ9ITS-WK48-r74988. It is available in New and Release.0
Hi there :-)
If have a pretty old Firmware on a ZyWall USG20 » 2.21(BDQ.4) / 1.14 / 2011-05-29 09:29:31 «
Is it possible to go directly to the leatest mentioned from you @Zyxel_Emily (…USG 20 3.30 BDQ - 330BDQ9ITS-WK48-r74988.zip… )?
What would be the steps, best practice to assure it's gone work.
Would this solve the issue I have when I want to access the Webinterface with the "EGDE-Browser"?
When I try it says:
"The connection to this website is not secure.192.168.0.1 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH"…with Firefox it works fine…
…see Screenshots:
Thanx in advance for any helpful answers.
Regards
Francesco0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
