USG20 want to upgrade firmware to latest
ryanchow
ryanchow Posts: 1 image  Freshman Member
edited January 2024 in Security
I have a USG 20 in use that I need to upgrade, if possible. Is this still supported or is it out of the question to upgrade to a current firmware? Let me know what other info is needed.
Model :  ZyWALL USG 20
Current firmware : 3.30(BDQ.9)
    PeterUK Posts: 4,268 image  Guru Member
    edited July 2022 Answer ✓
    The USG20 is EOL and you have the newest firmware
  • Zyxel_Emily
    The latest firmware for USG20 is 330BDQ9ITS-WK48-r74988. It is available in New and Release.
  • Hi there :-)
    If have a pretty old Firmware on a ZyWall USG20 » 2.21(BDQ.4) / 1.14 / 2011-05-29 09:29:31 «
    Is it possible to go directly to the leatest mentioned from you @Zyxel_Emily (…USG 20 3.30 BDQ - 330BDQ9ITS-WK48-r74988.zip… )?
    What would be the steps, best practice to assure it's gone work.
    Would this solve the issue I have when I want to access the Webinterface with the "EGDE-Browser"?
    When I try it says:
    "The connection to this website is not secure.192.168.0.1 uses an unsupported protocol.
    ERR_SSL_VERSION_OR_CIPHER_MISMATCH
    …with Firefox it works fine…
    …see Screenshots:
    ZyWall USG20 Version 2024-01-11_13h48_24.png Edge Error 2024-01-11 135050.png
    Thanx in advance for any helpful answers.
    Regards
    Francesco
