Certificate issue on a Windows Domain controller with Zyxel Firewall as gateway
I'm setting up a Windows Active Directory Server behind a zyxel Firewall.
The AD server has the ATP 500 Zyxel firewall as the gateway.
Every time i try to login in a computer of the domain, using a domain account,
i receive the following Security alert:
When i press "View Certificate" it says the problem is something connected to Zyxel
As a matter of fact, if i remove the ip address of the Zyxel firewall as the gateway of the AD server, the security alert disappears.
The firewall is an ATP500 running V5.30(ABFU.0)ITS-22WK20-r104104 firmware.
Any advice?
Thanks in advance for your help.
Regards
Filippo
Any advice?
Regards
Filippo
Hello @xkp68,It could be DNS query on the AD server is blocked by the DNS content filter profile.Once the HTTPS or DNS connection matched the category, the CF service will redirect a specific web page to you and the certificate will be replaced, resulting in the certificate does not match to the original URL.You may check the logs to see if the content filter block log exists.Thank you.James0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
