Wifi Bağlantı Kopma Sorunu
Shadow
Shadow Posts: 1 image  Freshman Member
edited May 2024 in Wireless
Kullandığım cihaz ile ilgili olarak, telefon üzerinden bağlandığım da hep kopmalar yaşanmakta veri kaybı yaşanmakta bu çok can sıkıcı bi hal almaya başladı bununla ilgi sorunumun giderilmesini rica ediyor
Türknet fiber kullanıyorum ama kablo harici bağlantıda sorun yaşıyorum ?????
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 516 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    Hi, @Shadow
    Welcome to the Zyxel Community!
    Could you kindly help us to check the AP firmware is up to date?
    If not, please upgrade to the latest firmware since there would be bug fixes and enhancements with the new AP firmware release, we would always suggest users keep the firmware with the latest one to ensure the best performance and experience.
    Please refer to the below link for downloading the latest AP firmware:
    Download Library | ZyXEL
    And make sure DCS is turned on and the DFS aware is turned off in your radio settings to increase channel selections to avoid interference from environmental problems.
    Please help us to observe whether the symptom still exist after you have done the settings.
    Thank you.
    Zyxel_HsinBo
    Untitled Image
