Login-in error
thanks for answer and help
Hi @PPommer1993
I have met once a time according "contact the Internet provider".
But the reason is coming from the IP address has overlap on WAN and LAN interface.
So every thing is working now after chagned LAN IP subnet as other subnet.
How about you sharing the screenshot that you met?
@PPommer1993
I think you missing some crucial information in your issue.. Because the SP300e is just a printer...
Guessing that you also then have a N4100 device
you can find the fix/explaintion hereMost recently, it seems that our older N4100 units encounter issues where clients instead of redirected to the captive portal are prompted with warning message that the connection is not secure.
This is due to the redirect being set to IP address 1.1.1.1 back then, which by now is reserved for the Cloudflare DNS server.
The solution to this issue is, to either create yourself a certificate according to the SOP guide (requires Linux machine) attached to this article.For customers who do not have this option, we have already created a certificate that can be implemented, which is also linked to this article.
Private key of the certificate is 12345Private Key File = private.key
Certificate File = Certificate.crt
You also need to set the SSL login page enabled on the N4100, screenshot below:
UPDATE:
Some of the latest Android devices will still show a "not secure" message after you uploaded the new certificate and applied the settings as mentioned above.
Here is what you have to do:
1. Factory Reset
2. Upload of the certificate and configuration as mentioned in the KB article
3. Configuration of the hot spotIMPORTANT: Do not apply the old config after factory reset. This will NOT work for this case.
documentation:
https://support.zyxel.eu/hc/en-us/article_attachments/360006748032/Certificate__generate.docxnew certificate:
https://support.zyxel.eu/hc/en-us/article_attachments/360006748052/n4100.zip0 -
Wir besitzen Das Modell GS 1100-16 funktioniert das Zertifikat auch für dieses Gerät?0
@PPommer1993
Nein das Zertifikat ist nur für die N41000
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
