Limitar banda por ip
LuisFlavio
Srs bom dia, existe uma possibilidade de limite de banda (internet) por ip no firewall USG110 Zyxel? se sim, como?
Good morning, is there a possibility of bandwidth limit (internet) per ip on the USG110 Zyxel firewall? if yes, how?
Hello @LuisFlavio,When we configure a BWM policy profile, we could select "Per-Source-IP"as BWM type.Please refer the screenshot below.
Select Per-Source-IP as BMW typeSelect LAN1 as Incoming InterfaceSelect WAN1 as Outgoing InterfaceSelect LAN1_subnet as SourceIt means that we want to set the bandwidth of each IP on LAN1Thanks,James0
Select Per-Source-IP as BMW typeSelect LAN1 as Incoming InterfaceSelect WAN1 as Outgoing InterfaceSelect LAN1_subnet as SourceIt means that we want to set the bandwidth of each IP on LAN1Thanks,James0 -
Caro Zyxel_James, muito obrigado pela resposta, resolvido minha dúvida, testado e ja em funcionamento0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
