Which repeater to use for a NWA3560 AP
we need to set up a new repeater for an existing Wlan system. That system is based on an UAG4100 and several NWA3560-N Wlan AP`s and the repeater/extender should be connected wireless (WDS) to avoid installing new cables.
Which repeater/extender/AP could be used for that instead of a NWA3560 which is not available anymore ?
Regards,
Sascha
Sascha
Hi @Sascha_S
Since NWA3560 is unavailable now, we suggest you can purchase WAC6502 or NWA5123-AC-HD.
However, NWA3560 only can establish WDS with NWA3k series. If you need to purchase new models, please establish a new WDS for them.I will send a private message to you and provide your local support to discuss for further purchase and question.
Thanks.
Joslyn5
Hi @Sascha_S
Thanks.
Joslyn5
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
