Zywall USG FLEX Series, ATP Series & VPN Series - V5.31 Firmware Release
Zyxel_Stanley
Release Note
July, 2022
Firmware Version on all models
USG FLEX | ATP | VPN | |||
USG FLEX 50 | V5.31(ABAQ.0) | ATP100 | V5.31(ABPS.0) | VPN50 | V5.31(ABHL.0) |
USG FLEX 50W | V5.31(ABAR.0) | ATP100W | V5.31(ABRW.0) | VPN100 | V5.31(ABFV.0) |
USG FLEX 100 | V5.31(ABUH.0) | ATP200 | V5.31(ABFW.0) | VPN300 | V5.31(ABFC.0) |
USG FLEX 100W | V5.31(ABWC.0) | ATP500 | V5.31(ABFU.0) | VPN1000 | V5.31(ABIP.0) |
USG FLEX 200 | V5.31(ABUI.0) | ATP700 | V5.31(ABTJ.0) | ||
USG FLEX 500 | V5.31(ABUJ.0) | ATP800 | V5.31(ABIQ.0) | ||
USG FLEX 700 | V5.31(ABWD.0) |
New Feature and Enhancements
CLD=Cloud mode, STD=Standalone mode
No. | Enhancement | CLD | STD |
1. | In the initial setup stage to detect LAN subnet if conflict with 192.168.1.1 then auto change to 192.168.10.1 redirect to myrouter.local | V | V |
2. | Login Users table add Created Date column as same as User Object | V | |
3. | Device GUI add Astra cloud portal URL | V | |
4. | [eITS#211100981] Email Security Blocklist add i-note information | V | |
5. | [eITS#220101060, 220101420, 220200439] Enhanced the information in the CDR logs | V | |
6. | [eITS#220500069] Monitor > Log > View Log > "Email Log Now" error message is not clear to us | V | |
7. | USG FLEX100 and USG FLEX 100W max. VPN tunnels number upgrade to 50 | V | |
8. | SSO feature enter maintenance mode and end of software service. | V | |
9. | Support access SNMP service from WAN interface | V |
Bug Fix
No. | Bug Fix | CLD | STD |
1. | eITS#211200767 a. Fix: Incorrect SSL VPN dashboard statistics information | V | |
2. | eITS#220100656 a. USG FLEX 200 / DNS Content filter functional Issue | V | |
3. | eITS#220101259 a. Fix: IP malfunctioning when the VLAN wan interface is configured with specific subnet mask | V | |
4. | eITS#220200044 a. Fix: Error message when visiting Sandboxing page | V | |
5. | eITS#220300054 a. Fix: Virtual Server LB disconnected issue | V | |
6. | eITS#220400122 a. Fix: Address Object manipulation issue | V | |
7. | eITS#220400688 a. Fix: Malfunctioning on IPSec Connectivity check button | V | |
8. | eITS#220400957 a. Fix: Incorrect wireless monitoring data | V | |
9. | eITS#220401137 a. Fix: DNSBL malfunctioning issue | V | |
10. | eITS#220401321 a. Fix: Wildcard FQDN object issue which may affect the system stability | V | |
11. | eITS#220500188 a. Fix: Packet forwarding issue on Trunk interface | V | |
12. | eITS#220500690 a. Fix: SSLVPN service port keeps using the original port after manually customized it | V | |
13. | eITS#220500701 a. Fix: GUI information correction | V | |
14. | eITS#220500751 a. Fix: SSLVPN connectivity issue | V | |
15. | eITS#220500939 a. Fix: DHCP service stability issue | V | |
16. | eITS#220501025 a. Fix: AAA radius COA will be turned on after firmware update to V5.30 | V | |
17. | eITS#220501052 a. Fix: VPN connectivity issue between Nebula and Non-Nebula VPN gateways | V | |
18. | eITS#220501182 a. Fix: VPN wizard malfunctioning issue | V | |
19. | eITS#220501267 a. Fix: Incorrect dashboard Virtual device Rear Panel wlan led status | V | |
20. | eITS#220501309 a. Fix: Static DHCP table importing issue | V | |
21. | eITS#220600336 a. Fix: Device stability enhancement | V | |
22. | eITS#220600447 a. Fix: What's new notification in the GUI malfunctioning. | V | |
23. | eITS#220600465 a. Fix: DHCP service stability issue | V | |
24. | Common vulnerabilities and Exposures: a. Local privilege escalation vulnerability fix (CVE-2022-30526) b. Authenticated directory traversal vulnerability fix (CVE-2022-2030) c. Security update of OpenSSL package (CVE-2022-0778) | V | V |
25. | eITS#220200349 a. Fix: Microsoft AD authentication not work | V | |
26. | eITS#220301020 a. Fix: BWM functional issue on USG FLEX 50(W) when the device is managed by NCC | V | |
27. | eITS#220500277 a. Fix: Google Authentication Bypass | V | |
28. | eITS#220600408 a. Fix: Nebula bwm cannot work on ftp active mode. | V |
Here are the further details on the security fixes noted above. See https://www.zyxel.com/us/en/support/Zyxel-security-advisory-authenticated-directory-traversal-vulnerabilities-of-firewalls.shtml and https://www.cve.org/CVERecord?id=CVE-2022-0778
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
