Unable to open port /NAT on USG40W
I have followed both of these guide to a "T" and my USG40W refuses to port forward:
https://mysupport.zyxel.com/hc/en-us/articles/360003880919--ZyWALL-USG-
How-to-open-ports-on-a-ZyWALL-USG-router-Port-Forwarding-NAT-
https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding-
I have checked and rechecked my objects and ports, but nothing seems to work in the logs I can see that traffic from expected IPs is trying to connect in because I get the following message:
There is definitely a policy at priority one that allows the appropriate service. What am i doing wrong here?
notice | Security Policy Control | Match default rule, DROP [count=22] |
Check the port role and port you are connected too
NAT instruct your device about how manage the packages.
Then security policy allows the traffic.
If you will publish (even masked/with data replaced) both NAT and Security policies i could analyze it and make my suggestions.0 -
In the NAT rule have you left "source IP" to any?0
Yes, source IP is set to any.
Yes I am familiar on this concept and I am pretty sure its configured correctlymMontana said:NAT instruct your device about how manage the packages.
NAT:
Security policy:
Preview
In config > network > interface that the device is connected to the port for Lan2
- 588 USG FLEX H Series
- 476 News and Release
