SFP+ uplinkport on XGS1930-52HP switch
JackAninco
Can we connect our server with a SFP+ Nic with this port or is the port only for uplink.
@JackAninco don't quote me on that, but even another switch is a "nic" for a switch port.Therefore, should work, IMVHO. You can still checkup the switch manual for more detailed info.0
@ivers
We are looking to make the connection. I see i can switch the Media type of the port to DAC 10G.
So i suppose i can connect my server. Do we need an Active or a passive dac cable.
I cannot find any info about this in the manual of the switch.0 -
@JackAninco,
If the cable is longer than 3m then we recommend using active DAC or Active optical cable if it is short than 1m then use passive DAC.0
- 588 USG FLEX H Series
- 477 News and Release
