VPN Policy Route on NSG 100
Hi
I am testing VPN connections between USG FLEX 100 and NSG 100 since USG FLEX is the new version of NSG.
My problem is that I cannot select VPN when I want to create a Policy Route on NSG, VPN is greyed out. What do I do to be able to create a Policy Route for traffic that will use the VPN connection?
Regards
Olav
No, I have not solved the problem, but I saw that the NSG series is End of Life, so I wonder if there will be a solution to this problem
End of life | Zyxel
h
Olav0 -
Hi @Elgen07,
When creating Nebula VPN tunnel between NSG and USG FLEX, you could not select VPN option when creating a Policy Route on NSG or USG FLEX.
This is a limitation on Nebula.
In order to select VPN in policy route, I suggest you create a Non-Nebula VPN on the site-to-site VPN setting page.
Here is the configuration example:
After saving the configuration, you will be able to select VPN when creating a Policy Route on NSG or USG FLEX.
In addition, if you want to create a policy route from NSG LAN to USG FLEX LAN, you only need to select "use VPN" for those LANs on the site-to-site VPN setting page. You don't need to manually create a policy route since Nebula will generate the policy after you select the option.
Zyxel Melen0 -
HiThanks for the reply, I've tested and I get the traffic through although it's not as good functionality as Nebula VPNhOlav0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
