Ubuntu VPN SSL Client for ZYXEL
paolo_biagini_75
paolo_biagini_75 Posts: 3 image  Freshman Member
Friend Collector
Hello everyone,
I need to connect to a SSL VPN ZYXEL, using the WIN7 client provided it works correctly under Win10 with the gateway IP, user and password provided by my customer. I would connect also from my Ubuntu 22.04 machine but I can't find a client for this OS, any hints on how I can connect from Ubuntu?
Thank you
Paolo
  • CHS
    CHS Posts: 181 image  Master Member
    There is no SSL VPN client for Linux OS. You could try to build VPN tunnel by other types. (e.g. L2TP VPN)
  • paolo_biagini_75
    Friend Collector
    I can connect only via SSL .. this is what my customer said to me
  • Zyxel_Stanley
    Hi @paolo_biagini_75
    Current SSL VPN client only support for Windows & MacOS platform.
    You may consider use L2TP VPN or IKEv2 VPN....etc.
  • paolo_biagini_75
    Friend Collector
    Hi @Zyxel_Stanley
    thanks for your answer, when you say that I should try use L2TP or IKEv2 could you be more detailed with some examples that could work for my OS?
    Thank you.
