ZyWALL USG 300 and TLS 1.2
13»
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    The firmware 330AQV7ITS-WK48-r74988 is sent to you in private message.
  • AG_DM
    AG_DM Posts: 2
    edited May 2022
    Hi @StouAdmin
    Welcome to Zyxel community
    I’ll sent you the firmware in private message.
    Hello!
    Can you sent me firmware 3.30(AQE.7)ITS-WK48-r74988?
    I have 5 devices
    ZyWALL USG 300 in different cities with fw 3.30(AQE.7), which doesn't have tls1.2
    And maybe you have fw for ZyWALL USG 50? On it now installed 3.30(BDS.7)ITS-WK28-r72114
    Update: i found all fw on the link from past messages :smile:
    Thank you!
  • Zyxel_Emily
  • Adinfo78
    Adinfo78 Posts: 1
    edited August 2022
    You need to upgrade ZyWALL USG 300 to the latest date firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support.
    The firmware is sent to you in private message.
    Hello, I know the topic that is old, but I have the same problem with TLS 1.2 customer support on the Zyxel USG 300, I need software 3.30 (AQE.7) ITS-WK48-r74988 for TLS 1.2 support, I will be grateful if I was able to go again.
    Edit:
    I hurried up too much, the last entry in the thread concerns, in any case available for download helped me.
    Edit2:
    Everything works!
    Router(config)# show ip http server secure status
    active               : yes
    port                 : 4440
    certificate          : default
    force redirect       : no
    authentication client: no
    anti beast attack    : no
    strong cipher suite  : yes
    cipher suite         : aes 3des des rc4
    ssl protocol         : tls1.2 tls1.1
    I am shocked that there was a solution for such an old USG 300 router.
    Thank you very much!
