ATP100 - Security Policy in Nebula
Hi , I need a VLAN to block all internet traffic except Microsoft OneDrive on Android tablets and Windows apps
I've done a thousand tests with the Security policies, but it doesn't seem to work.
Has anyone personally tested this setup?
Do you have screenshots of the working configuration?
Thanks in advance
Fabrizio F.
Fabrizio F.
Hi @FabrizioF
Currently, we don’t support this scenario. The App Patrol profile can only support reject action, it doesn’t support only allow some specific apps that can be passed on a firewall rule.
Zyxel_Jeff said:The App Patrol profile can only support reject action, it doesn’t support only allow some specific apps that can be passed on a firewall rule.
OUCH! What a giant feature hole!1 -
Hi @mMontanaThanks for your feedback and comment. We would consider transferring this request to our feature queue for our future development evaluation. Thanks.0
in the end I "solved" by blocking everything as much as possible, Looking at the logs I then unblocked the sites required by the OneDrive app ... at the moment it seems to work, fingers crossed1
Zyxel_Jeff said:
Hi @FabrizioF
however I seem to have understood that in on-premises mode, it is possible to change this parameter instead ...it is a bug / limitation of Nebula mode0 -
FabrizioF said:Zyxel_Jeff said:
Hi @FabrizioF
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
