Publish Email (Exchange On-premises) behind USG FLEX 200 Firewall
EdC
EdC Posts: 13 image  Freshman Member
Having a very hard time migrating from Sophos UTM to USG FLex 200.   I can't get my Exchange servers to be properly published.  I have tried both Virtual Server and 1:1NAT with limited success.  I have 5 Static IPs and per the KB, it seems 1:1Nat is most appropriate, but I am not sure.  But the bigger problem is how do I associate my domain-wide SSL certificates with those servers.  Apparently quite often when a remote client (Exchange ActiveSync or Outlook Remote) queries for the Server Certificate, the USG Flex 200 answers with its instead.  How do I get the USG Flex 200 to either pass through to the servers themselves to respond, or get it to respond properly with my domain wildcard?  I don't see anywhere in either Virtual Server or 1:1NAT to assign a certificate (which I do have loaded on the USG Flex 200)
Best Answers
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    ActiveSync uses port 443. Make sure the management port of flex 200 doesn't not conflict with 443. Here is a similar post. Follow the steps to change the management port of flex 200 to another.
  • EdC
    I fixed that and that will likely address the issue with getting the wrong certificate.  But I still have two questions -- why use Virtual Server vs. 1:1Nat.  The reference article says Virtual Server and several other KBs say 1:1Nat.  Not sure which is which.
    And the second question is why does the Microsoft Remote Connectivity Analyzer not work?  This is very strange... during Autodiscover I get this snippet..
    The Microsoft Connectivity Analyzer is probing the TCP endpoint 63.142.58.221 on port 443 to detect which SSL/TLS protocols and cipher suites are enabled.
    We were able to detect the enabled protocols and cipher suites.
    Additional Details
    TLS Protocol: SSL v3, Not enabled. TLS Protocol: TLS 1.0, Not enabled. TLS Protocol: TLS 1.1, Not enabled. TLS Protocol: TLS 1.2, Enabled cipher suites: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
    But then just seconds later I get this during the actual connect to validate Activesync settings:
    We were unable to determine which SSL and TLS protocols are enabled. This is usually because we couldn't connect.
    Has me stumped.  Does using 1:1NAT force only a single connection?  Is there another connection limit?
    Thanks for the help so far...
    -ed
  • jasailafan
  • EdC
    AHA -- so for an email server where IP address matters (because of DKIM, SPF, DMARC, etc.  1:1Nat is the way to go....   Thank you again
