Ubuntu VPN SSL Client for ZYXEL
paolo_biagini_75
in Security
Hello everyone,
I need to connect to a SSL VPN ZYXEL, using the WIN7 client provided it works correctly under Win10 with the gateway IP, user and password provided by my customer. I would connect also from my Ubuntu 22.04 machine but I can't find a client for this OS, any hints on how I can connect from Ubuntu?
Thank you
Paolo
Thank you
Paolo
There is no SSL VPN client for Linux OS. You could try to build VPN tunnel by other types. (e.g. L2TP VPN)
I can connect only via SSL .. this is what my customer said to me0
Hi @paolo_biagini_75
Current SSL VPN client only support for Windows & MacOS platform.
You may consider use L2TP VPN or IKEv2 VPN....etc.0 -
Hi @Zyxel_Stanley
thanks for your answer, when you say that I should try use L2TP or IKEv2 could you be more detailed with some examples that could work for my OS?
Thank you.0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 399 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 78 Security Highlight
