VPN BETWEEN ZYXEL ATP200 AND FRITZBOX! 7590
IKEv2. That's "normal".Create a new IKEv1 Gateway, key group could be none.Create new gateway, associate the gateway to the connection, then remove the old.0
IKEv1 and still same Key Group without „none“
You're correct and I'm wrong... I double checked on 4.x device few minutes ago.
According to this post
https://community.zyxel.com/en/discussion/comment/38965/#Comment_38965
maybe there's a different way, for allowing connection between Fritz device and the ATP, configuring the connection without PFS/Keygroup and the gateway with the key group.
You may have a try key group setting on ATP200:
Phase1(VPN Gateway): DH2
Phase2(VPN Connection): none
If still doesn't help, you can share VPN connection fail log entries.0 -
No Logs at USG310 !
The only log is at Fritzbox :IKE-Error 0x2026
"no proposal chosen"
Is there anyone really got a connection between those devices ?
Or do we talk about things that „normally has to work“ but nobody tested it in real conditions.
I can connect from my devices ( Mac,IPhone, IPad … ) to my Fritzbox (IPSec VPN-Server) or to my USG310 (IPSec/L2TP VPN-Server).
But still have problems Fritz tu USG !!!
Kepir said:No Logs at USG310 !
The log on Fritzbox said "no proposal chosen" means no matched rules on USG.
So that cloud be settings mismatch of IPSec rules on USG.
With IKE log of your USG can help to understand what's mismatch settings between both.
Make sure the IKE log is enable on your USG. And then post the logs you get.
@Kepir
Your VPN connection scenario is different as previous one which setting is "client to site VPN"...
Here is FRITZBOX site to site VPN configuration guide:
https://en.avm.de/service/vpn/tips-tricks/connecting-the-fritzbox-with-a-companys-vpn/
In IKEv1 setting on USG could be:
#6 The VPN ID on USG doesn't support space in setting, so you could enter FRITZBOX WAN IP address as VPN-ID on both of sites.
If your VPN tunnel still with the problem, you have to take screenshot on USG/FRITZBOX all IKE log entries....because there are too many reason will case no proposal chosen!!!0 -
Thank you @zyman2008 @CHS,
yesterday i found an other solution . i created vpn.cfg file and i have a stable vpn connection.
But i am not able to ping each other.
Here is my config .
Here some additional screenshots ..0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 917 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 915 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
