Switch ES-2024 - Ports Limited to 100 MB/s
gmg403
gmg403 Posts: 2 image  Freshman Member
edited August 2022 in Switch
All the ports of my Ethernet Switch ES-2024 are limited to 100MB/s. Can I increase that rate?
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Change the switch.
  • gmg403
    Thanks. Any recommendations?
  • mMontana
    Goals and requirements missing. Then I'll do the simplest evaluation: 24 PoE 1GBps ports.
    GS2220-28HP have 1GBps uplink and 375W PoE budget.
    Otherwise, you have to consider Layer 3 switches, quite more expensive.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @gmg403,
    Welcome to Zyxel community!
    Since ES-2024 does not support 1G/s on ethernet ports, you can consider purchasing a new switch to achieve your requirement.
    Here is two switch model I suggest:
    1. GS1900 Series: This series has 24/24E/24EP/24HP models for you to choose.
    2. GS1920 Series: This series has 24/24HP models for you to choose.
    In addition, may I know your requirement? So I could help to find which switch fulfills your needs.
    Zyxel Melen
