Switch ES-2024 - Ports Limited to 100 MB/s
Change the switch.
Thanks. Any recommendations?0
Goals and requirements missing. Then I'll do the simplest evaluation: 24 PoE 1GBps ports.GS2220-28HP have 1GBps uplink and 375W PoE budget.Otherwise, you have to consider Layer 3 switches, quite more expensive.0
Hi @gmg403,
Welcome to Zyxel community!
Since ES-2024 does not support 1G/s on ethernet ports, you can consider purchasing a new switch to achieve your requirement.
Here is two switch model I suggest:
1. GS1900 Series: This series has 24/24E/24EP/24HP models for you to choose.
2. GS1920 Series: This series has 24/24HP models for you to choose.
In addition, may I know your requirement? So I could help to find which switch fulfills your needs.Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
