Daily Log Report - msmtp: TLS certitifcate verification failed
psilva
psilva Posts: 2 image  Freshman Member
edited April 2021 in Security
I am trying to set up the daily log report but when I check the logs I get an info message saying:
msmtp: TLS certitifcate verification failed: unable to get local issuer certificate
I am using an outlook.com account as the log sender.
smtp-mail.outlook.com:587 TLS and STARTTLS are selected.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @psilva
    I checked the behavior by Gmail SMTP server. But it looks there is no this problem.
    The mail server may have some security settings which will deny the SMTP requests
    For Example, Gmail has some of the security setting.
    In Sign-in & security, users must allow less secure apps. Otherwise SMTP request will been denied.
  • Zyxel_Stanley
    Hi @psilva
     I tested on Microsoft mail server, the daily report still able send successfully.
    The Authentication server function should disabled.
    You can reference to my setting.
  • psilva
    Zyxel_Stanley the authenticate server option was enabled. Thanks.
