XGS1930-52HP VLAN
WACDLLC
WACDLLC Posts: 1
First Anniversary
edited August 2022 in Switch
I have 4 of these units and 1 is connected via an SPF + and the other ones are connected with a network cable. My VLAN 1 is working across all switches but my other VLANs are only working on the main switch. Main switch is assigning the VLAN DHCP & DNS correctly. I have trunk turned on on the upload feed of the sub switches but can’t get the feeds to work. All the switches are the same models.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,990 image  Guru Member
    Hi @WACDLLC,
    Welcome to Zyxel community!
    Can you share your topology and the VLAN configuration on all switches so I can help to check where could be wrong?
    Zyxel Melen
