ATP 100 doesn't forward ports
Hello, everyone,
on an APT 100, I configured the NAT rules, policy control, in the log I see that an access forward was performed, but I can't reach my web server at port 80.
If I try to reach my web server internally it works.
  • mMontana
    mMontana Posts: 1,434  Guru Member
    Your windows installation have only 1 gateway, currently FreeBSD.
    Windows receives packets from ATP100 (at least, should) but it will ask to FreeBSD (and not to ATP 100) to deliver answers, according to the network configuration.
«1
  • mMontana
    Does your webserver allows access outside the local network segment?
  • Yes, because it is already externally accessible from another wan
  • mMontana
    Do you have two routers/Firewall?
    The ATP100 and the "another wan"?
    PeterUK Posts: 4,036  Guru Member
    edited August 2022
    Does the APT 100 on the WAN have the WAN IP?
    Do a port scan to 80
    GRC | Port Authority, for Internet Port 80
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @october_web,
    Have you enabled "NAT loopback" ?
    In order to clarify issue, Please kindly provide the topology with IP address.
    Thank you
    Kevin
  • So,
    I have two Public IP and two Firewalls
    I did a scan, but port 80 does not appear to be open.
    Enable NAT Lookup is enabled.
    The public IP is 109.238.24.174
  • mMontana
    Would you please, @october_web, tell me if you have two devices for WAN connection (the ATP 100 and another device)?
  • Zyxel_Kevin
    Hi @october_web,
    1) Did you have another device on the WAN side ?
    2) Could you capture the LAN/WAN side packet  ?
    3) Please check internal server have port listened.
    Or we can have remote session for quikly check . Thank you
    Kevin
    yes
  • october_web
    october_web Posts: 7
    Friend Collector
    edited August 2022
    Hi @october_web,
    1) Did you have another device on the WAN side ? - NO
    2) Could you capture the LAN/WAN side packet  ? - how can I do it?
    3) Please check internal server have port listened. - port is listening
    Kevin
    I'm on holiday now, if I can't solve it when I get back. Thanks
