USG60W not pulling new AP firmware
PeterUK
PeterUK Posts: 4,446 image  Guru Member
My VPN300 can pull the 6.30 update but not my USG60W
Best Answers
  • CHS
    CHS Posts: 181 image  Master Member
    You can have a check it again. My USG60 can update to 6.30 firmware now.
  • Zyxel_Stanley
    Hi @PeterUK
    USG60W firmware is working on ZLD4.72 version.
    VPN300 firmware is working on ZLD5.3 version.
    Since different firmware version build-in different AP-Controller, so management AP firmware version are different.
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    Hi @PeterUK
    Good day,
    The firmware is preparing now,
    You can download the file next Monday
    Zyxel_Jay
  • CHS
    Its now showing up thanks
    Seems to of happened again my VPN300 pulls V6.40 Patch 6 but my USG60W is on V6.30 Patch 4
  • Zyxel_Stanley
    Hi @PeterUK
    But its the firmware for a AP WAX510D which I could get from here
    https://www.zyxel.com/support/download_landing/product/wax510d_14.shtml?c=gb&l=en&pid=20190701160006&tab=Firmware&pname=WAX510D
    I don't get why its different when the AP is being managed? Surely its the same firmware? I mean I could update the AP manually to V6.40 Patch 6 then back to managed right?
    edited August 2022
    Or maybe a new option is added to the AP that the old AP-Controller 4.72 does not know about that that the 5.3 does? Even so it should be easy to make the AP firmware compatible with both without the other options that the other don't support.
    So another question if you can't do the above is when the USG60W is EOL do I still get updates for the AP thats not EOL yet under the AP-Controller of USG60W?
  • Zyxel_Jay
    Hi @PeterUK
    Good day,
    Zyxel_Jay
