ATP100 - Configuration files - which are important?
I'm using an ATP100 and I'm backing up ALL configuration files before installing a firmware update.
But which configuration files are really important?
My ATP100 shows these 24 configuration files:
Can anyone please tell me which files to save before installing a firmware update?
Thanks.
And could I delete the other files that are not necessary?
Thanks.
Thanks.
Thanks.
Hi @e_mano_eMoreover, the ATP100 device would automatically back up the running-config file whenever firmware updating or if detecting the config be modified to avoid there is any accident occurred or the administrator forgets to back-up config. If you think those autobackup config files are useless for you, you could delete them. But, please reserve startup.conf ,last-good.conf, system-default.conf config files. For more details, you could refer to our User Guide from p.1059 to p.1063. Thanks.0
startup-config.conf
Is the one you want0 -
Hi @e_mano_e
Just as PeterUK mentioned, please back up the startup-config.conf firstly, it's the currently running config file. Thanks.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
