ATP 100 doesn't forward ports
2»
  • The scenario is this
  • mMontana
    mMontana Posts: 1,432  Guru Member
    Your windows installation have only 1 gateway, currently FreeBSD.
    Windows receives packets from ATP100 (at least, should) but it will ask to FreeBSD (and not to ATP 100) to deliver answers, according to the network configuration.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @october_web
    As mMontana said, please confirm the gateway of Windows point to ATP100 .
    If the issue persist. kindly provide the packet files in Private Messages .
    Thank you.
    Kevin
  • Then surely the problem is the windows server gateway which is currently set that of FreeBSD!
    Thank you all!!!
  • October
    October Posts: 4
    I set the right gateway and now the ports are forwarded correctly.
    Thank you all
