ATP 100 doesn't forward ports
The scenario is this
Your windows installation have only 1 gateway, currently FreeBSD.Windows receives packets from ATP100 (at least, should) but it will ask to FreeBSD (and not to ATP 100) to deliver answers, according to the network configuration.1
Hi @october_web,
As mMontana said, please confirm the gateway of Windows point to ATP100 .
If the issue persist. kindly provide the packet files in Private Messages .
Thank you.
Kevin0 -
Then surely the problem is the windows server gateway which is currently set that of FreeBSD!Thank you all!!!0
I set the right gateway and now the ports are forwarded correctly.Thank you all0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
