Problems uploading SCRIPT file
Infosetel2020
ZCNE Certified
ZCNE Certified
in Security
We have problems when uploading a SCRIPT file. The firewall connection screen remains in this state and is not updated. We have tried with different SCRIPT and different firewalls, but the problem is always the same.
We close the browser and re-enter the firewall and the file appears as uploaded.
As you can see, it is a very simple test file.
The firmware version of the equipment is the same in all of them. Version 5.31
Any idea what could be happening?
Thanks you,
Juan Antonio.
Are you using Firefox as browser?0
Hi mMontana,We use Google ChromeThanks,Juan Antonio
Hi,The version of Google Chrome we use is Versión 104.0.5112.81 (Build oficial) (64 bits)Thanks,Juan Antonio,
Would you please try with Firefox (currently quite the most non-blink-based browser).
If you're using a Mac, you can try Safari too (webkit)0 -
Hi mMontana,Correct operation with Firefox. It doesn't work with Google Chrome.Thanks,Juan Antonio,
Last try: open an incognito session in chrome, then try to upload a different script.0
Hi,Oops, this works okThe error had not occurred until now.Check cookie issueThank you,Juan Antonio
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
