Problems uploading SCRIPT file
Infosetel2020
Infosetel2020 Posts: 21  ZCNE Certified
Zyxel Certified Network Administrator - Security First Comment Friend Collector Fourth Anniversary
We have problems when uploading a SCRIPT file. The firewall connection screen remains in this state and is not updated. We have tried with different SCRIPT and different firewalls, but the problem is always the same.
We close the browser and re-enter the firewall and the file appears as uploaded.
As you can see, it is a very simple test file.
The firmware version of the equipment is the same in all of them. Version 5.31
Any idea what could be happening?
Thanks you,
Juan Antonio.
  • mMontana
    mMontana Posts: 1,402  Guru Member
    50 Answers 1000 Comments Friend Collector Fifth Anniversary
    Are you using Firefox as browser?
  • Infosetel2020
    Hi mMontana,
    We use Google Chrome
    Thanks,
    Juan Antonio
  • Infosetel2020
    The version of Google Chrome we use is Versión 104.0.5112.81 (Build oficial) (64 bits)
    Thanks,
    Juan Antonio,
  • mMontana
    Would you please try with Firefox (currently quite the most non-blink-based browser).
    If you're using a Mac, you can try Safari too (webkit)
  • Infosetel2020
    Hi mMontana,
    Correct operation with Firefox. It doesn't work with Google Chrome.
    Thanks,
    Juan Antonio,
  • mMontana
    Last try: open an incognito session in chrome, then try to upload a different script.
  • Infosetel2020
    Oops, this works ok
    The error had not occurred until now.
    Check cookie issue
    Thank you,
    Juan Antonio
