ZyWall 110 Stopped Working and Can't Log In after firmware upgrade
My Zywall 110 has been fine for a couple of years. Yesterday, for the first time ever, it required me to change the password and then installed a software update. At that point it stopped working as a firewall and I was unable to log in with either the new or the old password. Effectively, it is bricked. Either someone comes up with a fix or I am going to have to send it back to the factory for repair??
Hi @jschatzman,
Connect console and see if you can enter debug mode.
If you can enter debug mode, follow the FAQ to backup running configuration and upgrade ZyWALL 110 to the latest official firmware 4.35(AAAA.2).
Here is the FAQ for your reference.
How to backup running configuration if forgot password?
If there is no reaction on console or you cannot access the debug mode, you have to send the device to repair center.
O.k. that worked, after I figured out how to get my serial/usb converter to come online in less than 3 seconds.
Now I would like to reattach the firewall to my network for diagnostic purposes. How can I change its gateway address to something other than 192.168.1.1 so it won't conflict with my replacement firewall (e.g., change it to 192.168.0.1)?
Hi @jschatzman,
You can access the device via SSH or console and enter the following commands to change the interface IP.
Router# configure terminal
Router(config)# interface lan1
Router(config-if-lan1)# ip address 192.168.0.1 255.255.255.0
Router(config-if-lan1)# exit
Router(config)# ip dhcp pool LAN1_POOL
Router(config-ip-dhcp-pool)# network 192.168.0.0 255.255.255.0
Router(config-ip-dhcp-pool)# starting-address 192.168.0.33 pool-size 200
Router(config-ip-dhcp-pool)# default-router 192.168.0.1
Router(config-ip-dhcp-pool)# exit
Excuse me.jschatzman said:My Zywall 110 has been fine for a couple of years. Yesterday, for the first time ever, it required me to change the password and then installed a software update. At that point it stopped working as a firewall and I was unable to log in with either the new or the old password. Effectively, it is bricked. Either someone comes up with a fix or I am going to have to send it back to the factory for repair??
plz give the way you solved this problem. Today i had just updated the firmware for my zywall. And now i cannot log in it. Plz help me. I dont want to reset default, that is the last way. Plz help me.
Please see answers to my post. This was a bug in the firmware update at the time, which has not repeated AFAIK. I ended up doing a factory reset. Presumably, the process of updating would involve saving a backup of the configuration before doing the update. Otherwise, you will have to start from scratch. Sorry.My unit eventually died and I upgraded to a USG Flex 200. I have had no problems with the new unit.0
Hi @Hary1987
If you are lucky, you can find lastgood.conf in "conf" or "standby_conf" folder after logging to Firewall by FTP.
Thanks.jschatzman said:Please see answers to my post. This was a bug in the firmware update at the time, which has not repeated AFAIK. I ended up doing a factory reset. Presumably, the process of updating would involve saving a backup of the configuration before doing the update. Otherwise, you will have to start from scratch. Sorry.My unit eventually died and I upgraded to a USG Flex 200. I have had no problems with the new unit.So lucky, it just returned the previous configuration. I don’t know why it happen. And i found the old pasword and i can log in it. Then i tried upgrade FW again, it was success.Thank a lot for answer.0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
