GS1900-10HP - connection to VLAN trunk using a transparent bridge fails
I have Aruba 9004 gateway, Aruba 6200F switch and ZyXEL GS1900-10HP switch.
I have working VLAN configuration with 501,502,503,80 VLANs where Aruba 9004 is DHCP server. See the picture.
If I connect a CAT5E cable directly between Aruba 9004 port 3 and ZyXEL GS1900 port 9 Trunk, everything works and both ZyXEL and Aruba switches have VLANs available on configured ports and recieve IPs from DHCP.
As soon as I add a simple media converter (tried 3 different types - optics, VDSL) between Aruba 9004 and ZyXEL 1900, VLANs stop to work and no VLAN traffic passes through.
When I connect the same cable from media converter to a trunk port on Aruba 6200F, it works ok and VLANs are available on both ZyXEL and Aruba switches.
What could be wrong there?
Aruba 6200F switch
Aruba 6200F switch 0
The problem was MikroTik S-RJ01 SFP Module, which is written to be 10/100/1G but appearently it did not work properly with SFP port of the ZyXEL switch, it did not negotiate speed well probably. Port 8 as trunk works well.
SFP port with MikroTik S-RJ01 also showed as Fiber on the homescreen - switch schema, probably either ZyXEL or MikroTik problem.0
SFP port with MikroTik S-RJ01 also showed as Fiber on the homescreen - switch schema, probably either ZyXEL or MikroTik problem.0 -
Hi @Vodoca
You can try the Zyxel transceivers which are guaranteed to be compatible since they're fully tested and verified with our switch.
And the similar module with MikroTik S-RJ01is Zyxel SFP-1000T.
For other 3rd party ones, the compatibility is not guaranteed because there are numerous SFP in the market. It is impossible to verify all of them.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
