WAX 610D or WAX 630S
Hi @thai
The most difference between WAX610D and WAX630S is the antenna as below:
The WAX610D is equipped with a dual-optimized antenna that is selectable, allowing the access point to be mounted on the wall or on the ceiling.
The WAX630S built-in smart antenna is proven to be capable to co-channel interference, adaptively adjusts its antenna patterns to ensure the optimum performance is delivered.
Your PoE switch can meet both of the models’ requirement, you can consider the usage and deployment scenario in your house and choose. If you require any further information, feel free to contact us. Thank you
Regards,
Bella
- 603 USG FLEX H Series
- 481 News and Release
