Block youtube on selected Devices
DewaldH
DewaldH Posts: 1 image  Freshman Member
edited May 2024 in Wireless
I need to block youtube on selected device
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    Hi @DewaldH
    Our AP doesn't support blocking the website function.
    Usually, you can block the URL on your gateway.
    If you don't have gateway and AP, you can consider the Zyxel router NBG7510
    It has a wireless feature and it has a blacklist to block the URL.
    Zyxel_Jay
