Wake-on-Lan:
Best Answers
Hi @ jeffjohn1941
Due to the protocol is UDP, so you should not receive any response.
The error log is coming from this APP but not response from SBG. (You should clicked info button on APP) The error will not effects any problem to sends magic packet.
Please go to make sure your firewall rule.
Or you can capture the packets on your PC make sure it is able receive magic packet first.
5 -
Many sincere thanks for your assistance. I am embarrassed, however, to say that I now understand my problem was due to Win 10 Pro not supporting Wake from the PC power-OFF. After leaving in S3, (sleep) state no problems with Wake.Jeff J Purcell, New Forest, Uk and France, 442900
MS state:
In Windows 8, 8.1 and Windows 10, the default shutdown behavior puts the system into the hybrid shutdown state (S4), and all devices are put into D3. WOL from S4 or S5 is unsupported. Network adapters are explicitly not armed for WOL in either S5 or S4 cases because users expect zero power consumption and battery drain in the shutdown state. This behavior removes the possibility of invalid wake-ups when an explicit shutdown is requested. Therefore, WOL is supported only from sleep (S3) or hibernation (S4) states in Windows 8, 8.1 and Windows 10.
Hi @ jeffjohn1941(1) You can make sure you port forwarding setting is correct first.(2) And make sure firewall rule has forwarded the rule.(3) Go to add a static ARP on your SBG.e.g. arp -s 192.168.1.3 00:1E:33:28:4E:F9Then it should be work.
And you can reference to FAQ.0 -
Hi Stanley - thanks for your guidance. I did follow all of those settings (1-3) but without success. I am currently forwarding port 9 udp to the PC address. If I use Teamviewer, it does not wake. If I use a WoL app, should I use a broadcast address (192.168.1.255) or the specific IP address 192.168.1.12.
Jeff J Purcell, New Forest, Uk and France, 442900 -
Thanks for comments, but I have followed all the text book stuff, I believe. A thought though: my two PCs ( on different WANs) both have Norton NIS active - could this be the source of my difficulties?
Hi @ jeffjohn1941
If your PC is shutdown, then Norton service will stop working. So it will not effects WOL traffic.
But before shutting down you PC, you can make sure if PC is able receives magic packet succesfully. (you can capture packets by Wireshark)
And also I have paste my Teamviewer and 3rd party application(named WOL Control) configuration for your reference.
Many thanks for your support. I have tried via IoS phone using WOL CONTROL. This reports a Runtime Error; "application error occurred on server". SBG seems to be blocking. I have opened Ports 7:9 UDP/TCP to the dormant PC address. is this correct procedure?
Hi @ jeffjohn1941
5 -
Many thanks for your patience, but still no luck. I am away from my uk system (in France) currently but shall explore further with wireshark on my return in a few weeks. Most likely I shall use a remote power switch to wake the PC. ( I am assuming there should be no WoL problems with a Dell Vostro, as it is referenced in the BIOS and network card. My french system I waken using Aviosys DS9258 with no problems.
MS state:
MS quote:
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
