Vpn site-to-site two Usg20
Fran
Fran Posts: 5 image  Freshman Member
edited April 2021 in Security
I ask you for help with a problem that I can not solve.
I created a vpn site-to-site as instructed
FAQ_next_gen_usg_vpn_ipsec_site_to_site.pdf
What me server:
Print from site A> B result, it works.
Copying files from B> A result DOES NOT WORK
in practice, every file of more than a few kb (about 20) is blocked
and after about a minute I get the message that it is impossible to copy
this operation on the contrary generates the same problem
  I tried to create folders on servers, nas, local PCs also giving
  guest permissions and disabling Kaspesky
What can be the cause ?
Thanks for your help
  • Fran
    no help?
    I tried vatie keys, even very simple but not resolved.
    yet it seems to me a standard procedure
    could it be the different firmware version between the two devices?
    A
    3.30 (BDQ.4) / 1.17 / 2014-01-22 09:24:51
    B
    3.30 (BDQ.9) / 1.17 / 2016-11-22 09:50:31
  • Zyxel_Stanley
    Hi @Fran
    You can upgrade firmware to latest version.
    And try to enable “Ignore "Don't Fragment" setting in IP header” function on both of USG.
  • Fran
    Hi @Fran
    thank you
    This evening I will update and verify, return with the result.
  • Fran
    Also updated usg location A but by enabling the indicated item, when I try to copy the file everything stops and after about 20 seconds error appears.
    I usually use Mikrotik and it's never happened to me, I've got these two Zyxel from this client and I'm a little confused about why it happens, other help?
    Thank you very much
  • Fran
    Thank you very much
    update firmware 3.30(BDQ.9)C0
  • Zyxel_Stanley
    Hi @Fran
    I will send you private message for check this issue more detail.
