Vpn site-to-site two Usg20
I ask you for help with a problem that I can not solve.
I created a vpn site-to-site as instructed
FAQ_next_gen_usg_vpn_ipsec_site_to_site.pdf
What me server:
Print from site A> B result, it works.
Copying files from B> A result DOES NOT WORK
in practice, every file of more than a few kb (about 20) is blocked
and after about a minute I get the message that it is impossible to copy
this operation on the contrary generates the same problem
I tried to create folders on servers, nas, local PCs also giving
guest permissions and disabling Kaspesky
What can be the cause ?
Thanks for your help
no help?I tried vatie keys, even very simple but not resolved.
yet it seems to me a standard procedure
could it be the different firmware version between the two devices?
A
3.30 (BDQ.4) / 1.17 / 2014-01-22 09:24:51
B
3.30 (BDQ.9) / 1.17 / 2016-11-22 09:50:310 -
Hi @Fran
You can upgrade firmware to latest version.
And try to enable “Ignore "Don't Fragment" setting in IP header” function on both of USG.
Zyxel_Stanley said:
Hi @Fran
thank youThis evening I will update and verify, return with the result.0 -
Also updated usg location A but by enabling the indicated item, when I try to copy the file everything stops and after about 20 seconds error appears.I usually use Mikrotik and it's never happened to me, I've got these two Zyxel from this client and I'm a little confused about why it happens, other help?Thank you very much0
update firmware 3.30(BDQ.9)C0Fran said:Also updated usg location A but by enabling the indicated item, when I try to copy the file everything stops and after about 20 seconds error appears.I usually use Mikrotik and it's never happened to me, I've got these two Zyxel from this client and I'm a little confused about why it happens, other help?Thank you very much0 -
Hi @Fran
I will send you private message for check this issue more detail.0
- 603 USG FLEX H Series
- 481 News and Release
