GS1900-24E doesn't store config
I am facing a serious problem with one of my GS1900-24E.
I can configure the switch via web-gui and the values are stored in the running config.
But if I reboot the switch, it looses all its config.
What I tried so far:
- set the switch to factory default via web-gui -> still same behavior
- set the switch to factory default via hardware button -> still same behavior
- flash the switch to the latest firmware (V2.70(AAHK.3) -> still same behavior
- disconnect the switch from power for at least 1 minute -> still same behavior
I don't know what to do now. Any ideas?
kind regards
oelles
kind regards
oelles
Hi @oelles,
Welcome to Zyxel Communnity!
Since I don't see the issue on my GS1900-24E, I would like to clarify with you.
Once configuring switch settings via web GUI, configuration shows in the running config at the moment, but it doesn't store to backup config (start-up config). Switch will lose all config after rebooting.
From your description, I cannot assure if you've clicked SAVE button to backup your configuration.
You can backup your switch config via clicking save button on the top right.
Hope it helps,Adam
Hi @oelles,
Hope it helps,Adam
- 588 USG FLEX H Series
- 476 News and Release
